Error with VISA Read (-1073807346)
I am using VISA Write/Read to control a glucose monitor and read memory files. When I run the memory file for the first time, I recieve the error -1073807346, and the explanation is "VISA:  (Hex 0xBFFF000E) The given session or object reference is invalid."
However, when I run it again immediately afterwards (without doing anything except click run), it works perfectly every time until I close out the session and restart (then I receive the same error, but it works every time after that).
I have checked my settings, and they are correct, and I have also tried to run the command with Hyperterminal, and it works. I am not sure why it doesn't work the first time around.
Any help you could give would be great. I've attached the file ("Read Mem").
Thanks.
(3,723 Views)
Accepted by lltelford
Hi
Do you select the correct monitor resource (I guess you do) before starting the program?
Why do you have a sequence frame around your code? The sequencing is already done by the data wires.The last wait is nonsens.
And most important: why do you have a feedback node in your visa session just before the write.
Remove that and press on cleanup diagram.
greetings from the Netherlands
(3,718 Views)
Thanks -- the removal of the feedback node seems to have fixed the problem I had. Thanks for your help!
(3,713 Views)
