11-06-2012 01:39 PM
Hi
I'm trying to control a Keithley 6221 remotely via ethernet, but I'm having trouble detecting the device. The 6221 and PC are both connected to my university network, I've contacted the admin, who authorised the 6221 and gave it an IP address, and I can ping it from the PC using the IP address. However, MAX can't autodetect it, and I tried specifying the IP address, and MAX still couldn't find it.
I tried to connect the PC and 6221 together via a local network, with the 2 connected via a hub, and this worked fine, and I was able to detect the 6221 via MAX. However this isn't possible as a permanent solution, as I need external network access on the PC.
My config :Labview 2012, Win XP
11-06-2012 08:30 PM
Can't you give the Keithley a static IP address and add an alternate network configuration to your PC's NIC?
11-06-2012 09:27 PM
Hi NYC. The Keithley already has a static IP on the university network (because it didn't work in DHCP mode).
Could you expand on the altenate network config ? I'm not sure how that works.
11-07-2012 07:48 AM
Google is your friend.
11-07-2012 08:25 AM
Thankyou NYC ...
I don't understand how what you suggest would help my situation, so if you could give a bit more detail, then I would at least know what to look for on google.
11-07-2012 08:44 AM
You could also create your device manually in MAX.
Kees
11-07-2012 11:48 AM
Hi Kees
Yes I tried that. I entered the IP address manually, but not the "LAN device name" as I don't know what that is, and MAX couldn't detect my device. Is the LAN device name necessary, and if so, what is it ?
11-07-2012 12:16 PM
This is a pure shot in the dark, but it is sounding like there is a subnet and/or domain issue when using the public network.
11-07-2012 12:29 PM
Hi crossrulz
That might be the problem, although I can ping the generator with the computer. Could the problem be with MAX otherwise ?
11-09-2012 10:22 AM
Hi
I have myself serious problems with 6221 connecting via the ethernet interface. However, I think that the best for your case would be :
1. to install an additional ethernet card (10 usd) on your computer to which you can connect directly the 6221. this can have 192.168.0.1 address with 255.255.255.0 subnet mask and nothing for the gateway.
2. for 6221 you need to give it a fixed adress on the some domain such as 192.168.0.2, 0 on the gateway and 255.255.255.0 on the subnet mask.
now you have ethernet for 6221 with a fixed ip and you have internet with the other card.
I have this configuration and sometimes it works somethimes doesn't (I think that my device has a problem I contacted Keithley and try to find out), but at least on paper it is the best config.
Another option would be to have a routeur with NAT but this is more costly and in general more difficult to manage.
Wathever MAx says, you need to try to ping your source and if this is OK, try to use visa (if the passport is enabled ?! I think)
and the source address should be something like TCPIP::192.168.0.2::1394::SOCKET (or INSTR ?)
the port for the source 6221 is 1394
pls tell us how it is going
