03-14-2012 09:39 AM
Hello all,
I work with driver name ET24XX Instrument Driver to control the Eurotherm 2416 chamber.
I can read the temperature but get error while try to set the temperature value.
This is what I do:
Init:
et24xx.et24xx_Initialize("ASRL7::INSTR", 0, 9600, 0, 10, 1, m_hHandle)
et24xx.et24xx_SetControllerMode(m_hHandle, 0, 1)
Read:
et24xx.et24xx_ReadInputValues(m_hHandle, 0, 1, fMeasuredValue, fColdJunctionTemperature, p_fTemperature)
p_fTemperature is 27.5 (the temperature in the chamber)
Set:
float fValue = 22.2
et24xx.et24xx_ConfigureOPSetpointValue (m_hHandle, 1, fValue, 1)
return err : -1073807346 !!!
Please help,
Thanks in advanced,
03-15-2012 05:00 PM
This is not a device that NI specifically supports. I would recommend seeing if there is an example that came along with the device, or try contacting the vendor for the device.
Best of luck,
