Eurotherm 2416, fail Set Temperature (func: et24xx_ConfigureOPSetpointValue)
Hello all,
I work with driver name ET24XX Instrument Driver to control the Eurotherm 2416 chamber.
I can read the temperature but get error while try to set the temperature value.
This is what I do:
Init:
   et24xx.et24xx_Initialize("ASRL7::INSTR", 0, 9600, 0, 10, 1, m_hHandle)
   et24xx.et24xx_SetControllerMode(m_hHandle, 0, 1)
Read:
  et24xx.et24xx_ReadInputValues(m_hHandle, 0, 1, fMeasuredValue, fColdJunctionTemperature, p_fTemperature)
  p_fTemperature is 27.5 (the temperature in the chamber)
Set:
   float fValue = 22.2
   et24xx.et24xx_ConfigureOPSetpointValue (m_hHandle, 1, fValue, 1)
   return err : -1073807346 !!!
Please help,
Thanks in advanced,
(3,027 Views)
This is not a device that NI specifically supports.  I would recommend seeing if there is an example that came along with the device, or try contacting the vendor for the device.
Best of luck,
Ryan C.
(3,008 Views)
