Excel VBA using VISA crashing (Oct 2021)
I have been using Excel and Word to interface to test equipment (oscilloscope).
Recently (Oct 2021) Excel is crashing when I try to connect the scope (or any equipment on my GPIB bus).
    Set SCOPE1.Command.IO = io_mgr.Open("GPIB:: 12")
My code is ok as it has always worked before.
Similar code in Word is working fine --> hardware interface and VISA drivers are ok.
Looking and the bus data using Agilent Connection Expert IO Monitor I can see the the connection to the equipment is being made but Excel crashes - monitor file attached.
Before I try to roll back the Excel version I'd like to eliminate any other possible causes.  Has anyone seen similar problems lately?
D.
(3,554 Views)
Accepted by DP_Apps
If you are using Excel 16.0.14430.xxxxx, VISA is probably crashing due to a bug in Excel. (I did too)
In my case I avoided it by downgrading Excel to 16.0.14326.20404.
By the way, this is a NI bulletin board, the Keysight VISA topic is out of place.
(However, this issue occurs with both Keysight VISA and NI-VISA.)
(3,503 Views)
The latest build 16.0.14827.20158 resolves this issue.
I think you can apply this update if you have the latest channel contract with Office for Microsoft 365.
(2,676 Views)
Accepted by DP_Apps
Hi Iwa6,
Thanks for this.  This has worked on for me.
D.
(2,583 Views)
