Exception error NI 488.2
One of our older programs is not seeing the NI 488.2 driver, the message is :"Could not find load or assembly NationalInstruments.NI4882, Version=13.0.40.159, Culture=neutral, ect.
Does someone know what version of 488.2 this is revering to?
Regards
Paul
(2,999 Views)
Hi Paul,
I have taken a look into this question for you, and I don't believe this is referring to a version of NI-488.2, rather a dll "NationalInstruments.NI4882.dll" which is part of Visual Studio 2010 Version: 13.0.40.159.
There were these 2 references to it on the NI website, I have linked them in case that is of any help!
Good luck resolving the issue!
Kind regards,
Alice Boughton (MEng)
Technical Support Engineer
NI
(2,957 Views)
Accepted by topic author PvW
Hi Alice,
I will take a look into the 2 solutions over the weekend and see if they will help me. I will let you know either way.
R
(2,954 Views)
Alice, thanks for the solution. It work. It just took me soooo long to get to it. I was able to test the system and all is ok. P.
(2,797 Views)
