Exception error NI 488.2
One of our older programs is not seeing the NI 488.2 driver, the message is :"Could not find load or assembly NationalInstruments.NI4882, Version=13.0.40.159, Culture=neutral, ect.
Does someone know what version of 488.2 this is revering to?
Regards
Paul
(3,151 Views)
Hi Paul,
I have taken a look into this question for you, and I don't believe this is referring to a version of NI-488.2, rather a dll "NationalInstruments.NI4882.dll" which is part of Visual Studio 2010 Version: 13.0.40.159.
There were these 2 references to it on the NI website
  • ResetSystem Method
  • TestSystemForDeviceInformation Method
Good luck resolving the issue!
Kind regards,
Alice Boughton (MEng)
Technical Support Engineer
NI
(3,109 Views)
Accepted by topic author PvW
Hi Alice,
I will take a look into the 2 solutions over the weekend and see if they will help me. I will let you know either way.
R
(3,106 Views)
Alice, thanks for the solution. It work. It just took me soooo long to get to it. I was able to test the system and all is ok. P.
(2,949 Views)
