Executable file made on Labview 4.0.1 cannot locate driver DAQ-6.6 with PCI-6025E
My executable file made on Labview 4.0.1 cannot locate or open driver DAQ-6.6. I'm using a PCI-6025E card and a Win2000 operating system.
(3,279 Views)
The Application Builder Troubleshooting Wizard provides some useful steps to take when troubleshooting problems such as this. The first thing that you should check to see is that you have both the LabVIEW Run-Time engine and NI-DAQ 6.6 installed. If you do not have one or the other, then you application will not execute correctly.
Jared A
(3,279 Views)
