How do I communicate to a USB instrument
I just need a simple example of writing and reading
using the USB icons. I tried the example on
NI.com website but I keep getting error code
(6,211 Views)
Are you using the VISA USB icons? If so, this is a low-level mechanism for communication over USB. You would need your USB device's API (which endpoints are used, command formatting, etc.), etc. Is this what you're looking for?
(6,211 Views)
I am not using visa icons because I am not clear on
how to configur those. Instead I am using Visa open,
visa write,visa read, visa close. When I do I get a
error code -1073807343 from the visa read icon. The
VISA FIND RESOURCE icon works find, now if only I
could look inside of it to see how its communicating
with my device that would be great.
Attach is the command codes for the device from
the manufacture. All I want is a simple example
of how to communicate with this device through
the usb port, so that I can read the signal and
display it in labview's chart or graph.
Thank you
(6,211 Views)
Try using the VISA USB Out Control.vi and setting the index to 0x02 for the endpoint 2 and set the value to 0x01 for intialization. See if that works for your device. Once you can get one command to execute I am sure you can implement the rest. You might also want to try playing around with VISAIC (VISA interactive control in MAX) and NI-SPY until you are able to execute a command without getting an error.
-JoshuaP
(6,211 Views)
Thank you. You were very helpfull. Using your advise
I was able to get USB control in/out to work without
any errors. I also bought USB COMPLETE SECOND EDITION
which is very helpfull.
Thanks again
(6,211 Views)
