Extension capability not supported by instrument(Temperature)
I am using IVI driver to communicate to Keithley 2750  and read temperature from thermocouple,Type-K sensor.
I get an error -30717 (Extension capability not supported by Instrument(Temperature) when trying to read temperature.
I am able to read voltage,current and resistance directly by configuring IVI DMM from NI TestStand.
Please not that I have configured instrument for measuring voltage,current and resistance successfully. So I believe the initial set up and configuration are alright.
However I am not sure if this error is because of me not configuring the IVI step in correct order. I have attached screenshots of step configuration that I do.
Please provide any suggestions.
I have already posted this issue in Keithley forums. I have not heard from them yet.
Please find screenshots attached.
Please find the link for driver that I am using here: http://www.keithley.com/support/data?asset=52764
Sahithi
(4,136 Views)
Error screen shot attached here
(4,134 Views)
Temperature is not one of the base functions of a DMM class so the IVI, foundation added extended capabilites to the class. Assumimg that instrument itself supports a temperature measurement, it looks to me that there is a bug in the driver from Keithley.
(4,121 Views)
Thank you
The instrument supports temperature measurement. Because of this error,I ended up writing a function in C# to read temperature and it works !!
However I wanted to know if I was doing anything wrong. Thanks again
Sahithi
(4,113 Views)
