My installed devices do not show up in MAX
I have installed several device drivers via the "find instrument driver" utility in labview 2012.  I do not have them hooked up to the computer so I would like to simulate them; but when I go into MAX, only one of them shows up in the Driver Sessions area.  Where are all the rest?  When I go back into "find instrument driver" they all show up as installed.
(4,112 Views)
Are they all IVI drivers? Those are the only types that wil appear in MAX and they are the only types you can simulate.
(4,100 Views)
When I use the find instrument driver utility it doesn't say what type it is.  Is there some way to see that?
(4,098 Views)
I'm not at a computer now so I'm not sure. I thought that when multiple drivers were available, you had to choose. Its easy enough to install then manually, assumimg they exist at all.
(4,093 Views)
