You can do this also via bustriggering.
Look up Group Execute Trigger in the GPIB commands.
The triggering of all the instruments in the group is at the same time.
Afterwards you read out all the instruments after each other as for a normal read.
(except that you should not do a read but a fetch because a read also does a trigger.
greetings from the Netherlands
