Failed GPIB Command Causes Reboot of Win2k
I'm working with Delphi 5 and the dpib32 library to develop GPIB applications. We have a problem with the app rebooting PCs on win2k. My understanding is this is a BSOD but never shows becasue of system properties.
I have traced the problem down to a particular situation which I thought was handled. After making a useless call to a deveice... say VDC?, eventually there is a timeout. After the timeout I set ibonl(Device, 0); but the system never recovers. Upon closing the app there is a reboot.
Any idea how to get around this or what I need to do at the code level to (assuming here) 'disable' the device?
(3,244 Views)
This particular BSOD is fixed in driver versions 2.0 and above. I think to fix this in your code without changing the driver version, you should make sure that you take every device handle offline using ibonl(handle, 0).
Hope this helps.
(3,244 Views)
