FindLstn and board number higher then 0
Hello, I am working with code that has been written that use your GPIB SDK for talk to GPIB devices.  The company that I work for just revice a GPIB-ENET/100. The code that i am working with will talk to GPIB-ENET/100 using command "FindLstn" with a board number of "0", but when try to use this command with a board of  "1" none of the GPIB device will anwser.
If anyone can help me please do and if you need more info you can call me at 510 333 9920.
Paul Walker
(3,105 Views)
If you're using the FindLstn function that's in LabVIEW, then the bus number refers to the GPIB Bus number and if you only have a single GPIB controller, that is by default bus 0.  Bus 1 does not exist. Now, if you are trying to detect instruments connected to bus 0, you need to create an address list array to search for listeners. You can create an array with all possible GPIB addresses or have an array with a limited amount of addresses.
(3,102 Views)
