Firewire (IEEE 1394) control via Labview in a Windows NT 4.0 environment
What must be done to get a Firewire (IEEE 1394) interface working with Labview 6.i in a Windows NT 4.0 environment? Are the drivers required to configure a Firewire card included with Labview 6.i? The Firewire card used is an HP Firewire card.
(3,294 Views)
Hello-
First, be sure the card works in NT 4.0. If it does, HP probably has a version of VISA that can be used to access the 1394. Knowledge Base 20KCIS7Z talks about using VISA and HPIB cards in LabVIEW. I imagine this would be the same.
Randy Solomonson
(3,294 Views)
