Fluke 189 Multimeter Not Recognized as a VISA resource
Is the issue solved by you? Changing to RAW induce issue in the vi. No way to run it this way.
I am still fighting to use the FLUKE189 with Labview. I have LV10, VISA 5.0.3.
Any help would ... help. Thank you.
Message 11 of 13
(1,148 Views)
If you are using USB to communicate with the DMM, and it is USB RAW, then you will have to know specific information about USB communication with that device.
The USB standard describes four types of pipes or endpoints: control, bulk, interrupt, and isochronous. Each type of pipe transfers a different type of information. Furthermore, any number of endpoints can be of any endpoint type. Think of an endpoint as a communication socket.
NI-VISA supports three types of USB pipes: control, bulk, and interrupt. When NI-VISA detects your USB instrument, it automatically scans your instrument for the lowest available endpoint for each type.
NI-VISA includes four functions to transfer data through USB pipes. Before you can communicate with your device using these functions, you need to set up the communication protocol using the VISA USB attributes. The following list describes the available functions.
Use VISA USB Control In and VISA USB Control Out to transfer data using the control pipe.
VISA Read and VISA Write are used to communicate with USB Bulk Endpoints.
VISA Write is used to communicate with USB Interrupt Out Endpoints.
If you are using LabVIEW, VISA includes an additional function to use the interrupt pipe: VISA Get USB Interrupt Data. In the C API, you can do this by accessing the VI_ATTR_USB_RECV_INTR_SIZE and VI_ATTR_USB_RECV_INTR_DATA attributes of the VI_EVENT_USB_INTR event object. See the NI-VISA Programmer Reference Manual for more information about VISA Events.
A key step in communicating with a USB instrument is setting VISA as the driver linked to the device.  This is accomplished using the Driver Development Wizard. The Driver Development Wizard automatically pulls the manufacturer and device ID for connected USB devices and displays this information to the user (VISA 5.0 and later). Older versions of NI-VISA require the user to know the Device and Manufacturer ID to develop a driver. You can also manually create a driver for USB devices if not connected. The Driver Development Wizard will detect if the device is USBTMC or another known USB device class, and warn the user that creating a driver for these devices is not necessary.
Once you install this INF file into the appropriate folder, plugging the USB device into the computer will logically assign it to the VISA driver for handling.  You can then use VISA VI’s or functions to communicate with your USB instrument’s pipe.
You must know what sort of endpoints (control, bulk, or interrupt) are available on the device, and how to use those endpoints to communicate with your device.
That all being said (phew!), follow this tutorial:  http://zone.ni.com/devzone/cda/tut/p/id/4478
Hope this helps!
Sean N
Applications Engineering Specialist - Semiconductor Test
Message 12 of 13
(1,126 Views)
The instrument should appear in MAX as a serial port. I have no experience with a Mac but does Fluke's USB driver support it? The problem lies there. Trying to use the VISA wizard seems like a complete waste of time unless you can get the low level information from Fluke.
Message 13 of 13
(1,118 Views)
