GAPS gather Mario Visa read
http://www.adafruit.com/products/746#Technical_Details
Hey guys, I am coming here because earlier I had vision problems you guys were very helpful, I was able to do a match pattern program!
So I'm programming a GPS sensor, in particular the adafruit ultimate GPS, the SPECS are below, as well as a link above:
Satellites: 22 tracking, 66 searching
  • Patch Antenna Size: 15mm x 15mm x 4mm
  • Update rate: 1 to 10 Hz
  • Position Accuracy: 1.8 meters
  • Velocity Accuracy: 0.1 meters/s
  • Warm/cold start: 34 seconds
  • Acquisition sensitivity: -145 dBm
  • Tracking sensitivity: -165 dBm
  • Maximum Altitude for PA6H: according to the factory, this module will perform up to 40Km but it is only known-tested up to 27,000 Meters
  • Maximum Velocity: 515m/s
  • Vin range: 3.0-5.5VDC
  • MTK3339 Operating current: 25mA tracking, 20 mA current draw during navigation
  • Output: NMEA 0183, 9600 baud default
  • DGPS/WAAS/EGNOS supported
  • FCC E911 compliance and AGPS support (Offline mode : EPO valid up to 14 days )
  • Up to 210 PRN channels
  • Jammer detection and reduction
  • Multi-path detection and compensation
  • Firmware version 5153
For pins I am using 1  for vin
                               10 for RX
                               14 for tx
                                30 for ground
Upon running the program, from the myRio essentials manual,  I get the dreaded visa run-out issue(which can be seen in the attachment, as well as below).  Any ideas?  I have scoured everywhere to find a solution, and have yet to find anything that actual works.  Hope you guys can offer me some advice!
The pickel!
(4,832 Views)
Isn't the post at http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/visa-read-gps/td-p/2758850 exactly the same as this? Did you create a new user name? Have you done any of the suggestions in the original thread?
(4,822 Views)
Yeah looks like this guy is having the same issue's, I got a couple of suggestions for him I have already worked out.
I'll move to that forum though, sorry for not searching the boards.  I usually think my issue is the only one of the sort.
The pickel!
(4,809 Views)
Sorry, your post was so similar to the one I linked that I thought you were the same. I've made some comments to the other thread.
(4,797 Views)
