GPIB A Driver problem
I have to do some measurements using a GPIB A with win2000. With the new drivers 2.4 windows tells me this is an obsolete hardware and it cannot find a good driver, so I tried to download the file ni488222 as suggested. Now, the file during the download process is about 111M but at the end it is just 10M; also when I try to open it windows tells me that this is not a valid win32 application (I downloaded the win2000 version).
Can someone help me?
Matteo
(3,411 Views)
Hey Matteo,
To find the correct version for your device. I would recommend taking a look at this GPIB Driver Compatibility Link. When you click on the driver, it will say at the top which OS it supports.
Can you let me know if this link helps you out?
Nick D.
(3,389 Views)
