PXI-8433 serial card not visible in MAX
I have a running remote PXI system using RT, but now I need to connect it to some new remote instruments on 2-wire RS-485 system at a custom baud rate of 40,960.
Selected the NI PXI-8433/4 4-Port, 2000 V Isolated, PXI Serial Interface for RS485/422.
Inserted the PXI-8433 card but MAX, talking to the remote processor, does not find the card. Same problem with a second PXI-8433 card in a second remote RT system.
I'm guessing I don't have proper card driver software installed into remote processor, so I have attached a screen shot of MAX showing the software installed into the remote processor.
Does anyone have a suggestion for the next move here? Thanks,
Jerry
(3,688 Views)
Hi Jerry,
The card itself will not show up.  You will just be adding COM ports under "Ports (Serial & Parallel).  To add the new additional COM ports right click on Ports and click "Create New Port."
John E.
Applications Engineering
(3,613 Views)
