GPIB-CPU Timing Issue (Generic I/O error)
Greetings!
I'm currently working on the development of a Flash Photolysis instrument using Labview 2009 and have recently upgraded our computer but have run into some issues. At random points there is a generic I/O error within the messagesend.vi, but the errors do not occur when using the lamp tool. After doing some research I have found that upgrading our computer has caused some timing issues where the instrument and the computer are not communicating properly.
I was curious if anyone has had experience in changing the PCI-GPIB card settings so that the instrument will ping properly with the computer and fix this timing issue.
Thanks!
(5,130 Views)
That kind of timing issues is probably more a question of bad programming (race conditions, and not using the error lines).
Ofte these come up when moving to a new cpu but to be sure you need to send the program.
You can attach a zip file with all of your program.
greetings from the Netherlands
(5,114 Views)
I believe you're right! I've found that my error occurs at the GPIBwrite command, would the two strings here cause a race condition during the writing process?
(5,094 Views)
Hi
This vi is ok. All wires that are connected to a function or subvi are guaranteed to have a value before the function or subvi is executed.
Search for local variables and value property nodes, these are very prone to race conditions.
(5,075 Views)
