String Subset from Serial error
Hi Everyone
I have  a simple program. I have used arduino to tranfer some string to labview.
And In Labview I want to Subset string. But, It is working only first string and the later strings not be subset.
Can you help me find my error?
Thank for reading
Here is my code and my error
Here is my Video: https://www.youtube.com/watch?v=Gm5nOrZ3iyo
Here is my arduino code:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
int i=0;
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x20 for a 16 chars and 2 line display
void setup()
  lcd.init();    // initialize the lcd
  Serial.begin(9600);
 // attachInterrupt(0,irt1,CHANGE);
  attachInterrupt(1,irt2,FALLING);
  // Print a message to the LCD.
  lcd.backlight();
  lcd.print("Hello, world!");
  Serial.print("Hello, world\n");
  delay(1000);
  lcd.clear();
void loop()
  while(Serial.available())
  char r = (char) Serial.read();
  if(r=='t')
    lcd.setCursor(0,0);
  lcd.print("you are robot");
 // Serial.print("you are robot\n");
  else if (r='a')
    lcd.setCursor(0,0);
    lcd.print("you are human");
   // Serial.print("you are human\n");
void irt2()
  delay(1500);
  i++;
  if(i%2)
 { Serial.print("ngaysinh010071992\n");}
  else
  {Serial.print("ngaysinh123455\n");}
(6,361 Views)
That feedback node is keeping all of the read data.  The first 7 bytes will never change since they will always be from the first message.  Since I'm sure you just want to see the latest message, just wire the substring indicator to the data coming out of the VISA Read.
Let's take care of some other issues while we are at it.
1. Get rid of the Bytes At Port.  You are using the Termination Character.  So let VISA use it.  The VISA Read will stop reading when it encounters the termination character or it reads the number of bytes specified, whichever comes first.  So use a constant to tell the VISA Read to read a larger number of bytes than you would ever get from a message.
2. The VISA Clear isn't really needed.
(6,358 Views)
thank for support.
Let me try again
(6,355 Views)
Hi. I have tried but It still not working.
Morever, I want to compare input string with constant string. But It working only with first string
I know feedback node is problem, But I can not fix it.
Can you help me fix it?
thanks
(6,339 Views)
Your Read Buffer is EVERYTHING that you have received.  Any comparisons you want to do should only be on the CURRENT message.  So the output of the VISA Read should be going to the Equals function, not the output of the Concatinate String.
(6,337 Views)
How can I fix it? Please help me
(6,335 Views)
Accepted by topic author xaxa9ztb
I went ahead and did some cleaning up of your diagram.  See if this makes sense.
(6,330 Views)
