I was installing labVIEW 7.0 and NI DAQ 7.1 on my new XP Computer. I ended up with the error message on startup as documented here: (Document ID: 2DJFRS00)
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/86256a47004e16d186256acd0078478a?OpenDocument
So I deleted the value and the error message, and instead got this one:
16 bit MS-DOS Subsytem
C:\WINDOWS\system32\cmd.exe
SYSTEM\CurrentControlSet\Control\Virtual Device Drivers. Virtual Device Driver format in the registery is invaild. Choose 'Close" to terminate the application.
[Close] [Ingore]
So I have now uninstalled all NI software, and it still occurs.
I do not have any GPIB hardware.
I
have also checked out Document ID: 0AQIJHEO
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/46c2096dc27898298625646d006ca667?OpenDocument
I do not follow the instructions how to disable the drivers at startup.
Alternatively when I go about reinstalling LabVIEW and NI DAQ, what should I make sure I install to get rid of this error?
Thanks for you help in advance.
Nicholas Murray
