Rats. During some hyperactive browsing for modem-control lines and 485 equipment after seeing the problem, I seem to remember that W2K had better synchronization, but I've also read earlier (few yrs ago, pre-LabVIEW) that Windows generally didn't do modem lines well, but that was the earlier versions. This was pre-W2K, perhaps pre-NT 4.0.
Why is it that the modem-control is there in the driver if it doesn't work well under W2K? I'm going to hazard a guess that under LV RT, it works as would be expected.
We will continue to balance the lines until I make comparisons to Blue Heat cards, or the B&B & Telebyte devices
😕 Often, it's only the first couple of packets that get mangled.
Hmm, are there examples of softwa
re timing? How well does it work? The one-millisecond resolution of the clock wouldn't seem to be too useful, as that's too slow.
Bob Seegmiller
NG UMS Ryan Aeronautical Center
