GPIB Device doesnot respond to *IDN? QUERY
HELLO,
I Am trying to interface  my GPIB instrument with HOST computer through LabVIEW, unfortunately my GPIB instrument doesnot respond to *IDN? QUERY. Could not find out what is problem with this. Could anyone can help in this regard.
Ameer
Message 1 of 11
(6,171 Views)
Are you sure the instrument should respond to a *IDN?
Does it say it does in the manual?
Message 2 of 11
(6,169 Views)
ya the GPIB instrument "doesnot" respond to *IDN? query
Message 3 of 11
(6,162 Views)
Huh? Care to rephrase your answer to my question.
Message 4 of 11
(6,156 Views)
Ameer,
It seems you are a beginner with GPIB instruments. Not all instruments will respond to the *IDN? query. You failed to mention the make and model and that is vital information. Look in the programming manual to see whether *IDN? is listed. If it is not, then simply ignore the warning. If it is listed, then you can start to worry.
Message 5 of 11
(6,154 Views)
Just one addtion: there are even some instruments ( like the agilent 603x powersupplies) which support two different sets of command languages. One set supports the*IDN? query but the other set not.
Message 6 of 11
(6,136 Views)
If the product specification of your instrument says IEEE488.2-compliant (and optionally SCPI language compliant), the instrument must respond to an *IDN? query. Otherwise it may or may not understand the *IDN? query.
Message 7 of 11
(6,106 Views)
In my instrument manual nowhere is written about *IDN? query and anything related to it.
Message 8 of 11
(6,086 Views)
Am using HORIBA MEXA 9000 series vehicle exhast gas analyser. it is pre 1990s model. and CVS system.
Message 9 of 11
(6,084 Views)
My product specification is IEEE488 it uses ASCII 1978 model.
Message 10 of 11
(6,083 Views)
