GPIB Error during PM Initialize - EDVR
I have a GPIB interface (100MB ENET, P/N 778209-01) that gives this message when initialized into use during testing:
GPIB: Board name passed in an ibfind call is not configured in handle (software problem)
This GPIB unit is being controlled by a Tru64 UNIX system problem)
(3,450 Views)
Have you checked what the error message suggests, that the string passed to ibfind() is a valid board name?  The next thing to check would make sure that the board is setup correctly in the ibconf config utility.  Look at the hostname/IP on the board and then try to ping the box via that identifier.  Does it respond?
Scott B.
GPIB Software
(3,435 Views)
