GPIB Hardware returns incorrect data
I have a Fluke Data Logger that is used to read
temperature values on GPIB system that includes 8
HP multimeters and 4 HP power supplies. On an
infrequent basis, the Fluke will return a
temperature value of 0.0 regardless of what is
indicated on the front panel. It will continue to
return 0.0 on all channels until the control PC is
rebooted. The communication with the data logger
appears to be in order as it will change channels
when data is requested.
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 1
(5,301 Views)
