GPIB PROGRAM FOR TEMPFORCE
Hi all,
I want to write a program  to tempforce(temptronic) so that my program will control the tempforce like Compressor, Head up/down, heat and cold temperature.
please help me how to write the program its very urgent now.
thank you.
(6,679 Views)
Accepted by patil441
First, find the manual.  It should contain the commands you need to send to it via the GPIB bus.  Learn those.  From there, it is a matter of using some string manipulations to build up those commands and using VISA to send them.
(6,670 Views)
Hi all,
I am trying to write a program that can test the memory devices like SRAM/RAM something like that can any one please suggest me how to start or how to write that program, if you have any example code or sample VI's please send me.
Pavan Patil.
(6,614 Views)
Why did you mark the thread as solved? What does sram/ram have to do with your original question? Are you now talking about a different instrument? You really need to provide more information.
(6,611 Views)
thanks for your responce
my question is about next post i.e.different instrument usage purpose i have posted.
(6,607 Views)
You should start a new thread and provide the additional details I requested. The main information that is missing is the make and model of the new instrument, programming manual, your code, exact problem you have with your code, etc.
Please consider that this thread is closed and don't post here anymore.
(6,604 Views)
