Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
GPIB-USB-B on a Dell Latitude CPi A-Series
DAlain
Member
10-27-2003
12:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Can I use your NI GPIB-USB-B on a Dell Latitude CPi A-Series laptop? (Is the
USB versions are compatible ?)
Thank you
Denis Alain
Canadian Space Agency
St-Hubert, Qc Canada
0
Kudos
Message
1
of 2
(3,303 Views)
Reply
Re: GPIB-USB-B on a Dell Latitude CPi A-Series
DiegoF
NI Employee (retired)
10-28-2003
04:21 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Denis,
The USB-GPIB-B uses the USB 1.1 specification. Check out this knowledge base article
With Which USB Specification Does the GPIB-USB-B Comply?
You should also check for the available drivers for a given OS at
GPIB driver versions
DiegoF
National Instruments.
0
Kudos
Message
2
of 2
(3,303 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
