GPIB-USB-B on a Dell Latitude CPi A-Series
Can I use your NI GPIB-USB-B on a Dell Latitude CPi A-Series laptop? (Is the
USB versions are compatible ?)
Thank you
Denis Alain
Canadian Space Agency
St-Hubert, Qc Canada
(3,389 Views)
Hi Denis,
The USB-GPIB-B uses the USB 1.1 specification. Check out this knowledge base article With Which USB Specification Does the GPIB-USB-B Comply?.
You should also check for the available drivers for a given OS at GPIB driver versions.
DiegoF
National Instruments.
(3,389 Views)
