GPIB-USB-B
how to programme GPIB-USB-B in VB OR vc??Could you give me a example? Thanks a lot!!
(4,681 Views)
There are a number of examples that get installed with NI's GPIB driver (NI-488.2). Go to C:\Program Files\National Instruments\NI-488.2\Languages, where you'll find example programs in C and VB.
(4,680 Views)
but the example seems to be programmed for pci-gpib. what is the difference i should pay attention to when programming on usb-gpib-b and pci-gpib??
(4,680 Views)
There is no difference between programming with a USB-GPIB-B and an PCI-GPIB, both interfaces use the same commands and are used exactly the same way. Keep in mind board index applies to both USB and PCI interfaces. The board index of GPIB0 is 0, GPIB1 is 1, etc. Check Measurement and Automation Explorer to see what your interface's board index is.
(4,680 Views)
