GPIB-USB-HS Last time accessed
Anyone knows if it is a way to know the last time that an USB-GPIB-HS was used in my computer?
(3,572 Views)
Hi Axcel what exactly do you want to know? The last time the GPIB was connected to your computer? or the last time it was used on a program? If you can explain for what do you need it there may be a work around.
Best Regards
Message Edited by BeCeGa on 01-10-2007 12:21 PM
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,531 Views)
I wanted to know the last time the hardware named "USB-GPIB-HS" was connected to my computer. If it helps It was only used by the NI Explorer.
Why do I need that? -To keep track of the hardware used in a specific computer.
AD
(3,493 Views)
Hi Axel_DSR
If you need to monitor, record, and display the NI-488.2 calls made from NI-488.2 applications,
right-click on your GPIB instrument  (MAX) in the configuration tree, and select NI Spy.
By default, capture is off when you open NI Spy. You can change the default through the Spy»Options dialog box.
You can check the NI Spy help for more information.
I  attach an image about MAX - NI Spy
También el servicio de los foros puede ser utilizado en español si así lo prefieres
Coamín Cruz
AELATAM
(3,430 Views)
