01-05-2007 01:59 PM
01-10-2007 01:19 PM - edited 01-10-2007 01:19 PM
Hi Axcel what exactly do you want to know? The last time the GPIB was connected to your computer? or the last time it was used on a program? If you can explain for what do you need it there may be a work around.
Message Edited by BeCeGa on 01-10-2007 12:21 PM
01-15-2007 11:26 PM
02-12-2007 10:10 AM
Hi Axel_DSR
If you need to monitor, record, and display the NI-488.2 calls made from NI-488.2 applications,
right-click on your GPIB instrument (MAX) in the configuration tree, and select NI Spy.
By default, capture is off when you open NI Spy. You can change the default through the Spy»Options dialog box.
You can check the NI Spy help for more information.
I attach an image about MAX - NI Spy
También el servicio de los foros puede ser utilizado en español si así lo prefieres
Coamín Cruz
AELATAM
