GPIB-USB-HS driver not working under Windows 10
I am having a similar problem with windows 10 and even my device manager could not recognize GPIB USB. It is showing it as unrecognized usb with error 43. I have uninstalled and installed multiple times. Still the problem persists.
Message 11 of 13
(1,993 Views)
Hi Ryan,
It seems to me that I encounter the same issue as you. Can you kindly share how you clean up registry/reference related to NI software? (like which folder) I would like to give it a try. Unfortunately, win10 still give me this issue in 2020.
Thanks for your help.
PY
Message 12 of 13
(1,585 Views)
I've just upgraded to windows 10 on a machine - and made a completely fresh install of labview 2020 (32 bit) - and have exactly this problem.
It's not obvious from this thread this was solved in a coherent way (like how many times am I likely to have to reinstall labview to make it work?).
Any suggestions ?
Niels
Message 13 of 13
(1,297 Views)
