GPIB-USB-HS used through potentiostat 263A, iberr=EABO
I'm having some issues regarding a visa read through gpib-usb-hs. it responds to some commands such as "M" or "ID" but does not respond to *IDN? and comes out as an iberr = eabo error.
attached is an ni spy, and the error details. if anyone can help that would be great!
(4,088 Views)
Did you look in the manual to see if the instrument supports the command? You did not post the manual or even the make and model so no one can help you with what is there. Many older instruments don't so just ignore the warning.
(4,085 Views)
http://www.artisan-scientific.com/info/PAR_263A_Users_Manual.pdf
http://www.artisan-scientific.com/info/PAR_263A_Command_Set_Handbook.pdf
if these would help. i usually get timeout errors at random times on the visa read when using labVIEW and the error code on MAX and labVIEW are the same. are they related?
(4,076 Views)
What commands are you sending when you get the timeout error?
(4,065 Views)
under the error.jpg, you can see that the visa read with count 100 shows the time out error "bfff0015" when it is run under the visa software/max. When i run a program through labview, i get this time out error at random times. i think they are related and i'm not sure how to fix this?
(4,060 Views)
You can fix it by sending the correct command before doing a read. Clearly, sending an *IDN? has already been established as an unsupported command so what else are you writing when you get the error with a read?
(4,051 Views)
