GPIB-USB-HS with Yokogawa WT210
I am using the GPIB-USB-HS driver v3.0 with Yokogawa WTviewer to log data to a PC running Windows 7 Enterprise. The WTviewer application loads fine, but displays bogus values. Not sure if it is due to driver incompatibility..
Appreciate the help
(3,782 Views)
What language are you programming in (LabVIEW, C, C++, etc.)?  Also, here is a link to drivers for you specific device.  If you are not already using this driver, give it a shot.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1804
Also, in what way are the values different from what you expect to see?
Greg H.
(3,758 Views)
