01-13-2012 05:13 PM
I am using the GPIB-USB-HS driver v3.0 with Yokogawa WTviewer to log data to a PC running Windows 7 Enterprise. The WTviewer application loads fine, but displays bogus values. Not sure if it is due to driver incompatibility..
Appreciate the help
01-16-2012 01:07 PM
What language are you programming in (LabVIEW, C, C++, etc.)? Also, here is a link to drivers for you specific device. If you are not already using this driver, give it a shot.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1804
Also, in what way are the values different from what you expect to see?
Greg H.
