GPIB-USB to HP6675A
Trying to connect to a HP6675A power supply using a GPIB-USB Interface
Need library location and program examples.
Thanks!
(5,264 Views)
For what programming language? For LabVIEW, simply use Help> Find Instrument Drivers.
You should of course need to first install NI-488 and NI-VISA.
(5,261 Views)
Thanks. That was quick!
Also I want to find out if possible to simulate the data (voltage,current,setup parameters) when the device (HP6675A power supply) is not present
(5,258 Views)
Accepted by confused2000
Simulation is only possible with IVI.
(5,253 Views)
Thanks again for your quick response.
Sorry for the over-simple questions.
I have to expend sometime reading the basics.
Thanks again
(5,250 Views)
Please mark one of my answers as the solution instead of your thank you. You can do this by clicking on Options above the text box. It will just help searchers find an answer quicker.
(5,243 Views)
