GPIB VM700 Control
hi I'm trying to control a Tektronix Vm700T via GPIB. Everything works fine. I control this with a normal visa port by using the functions you can found in the vm700 manual.
But I do not know how to copy the screnview to my vi.
When I use the VMTWin Software the command is:
"screencopy test.elq
convert test.elq test.bmp"
May somebody know how to implement this in labview.
thanks a lot
jens
(3,916 Views)
Did you ever figure this out? I am currently trying to do the exact same thing. Please contact me if you have any useful information, thank you.
Amiri
amiri.mccain@onsemi.com
(3,835 Views)
