How associate a boolean element wiht a text on an array
Hello!!!
Two weeks ago I tried to do an alarms sequencer and it is almost ready, but now I need to associate a boolean element with a text. The booleans are an array and each one must have a different text. Have anyone an example, how to do that?
Kind Regards,
LavUser
(4,236 Views)
It's not clear to me what you are saying. Smiley Surprised  Can you tell a bit more about what you want.
(4,227 Views)
I will try to explain you. I am working with modbus protocol and I have some booleans. Those booleans I must show on a display as alarms. And from modbus protocol I get the booleans as an array. From this array I can now see as well with boolean is activ as the index. So, now I need to put a label by index, because the index gib me the bit. Together with this email I send you my little programm, maybe you could see.
Note: I am using an array to simulate the original but it is the same thing.
In advance I thank you and I hope you could understand.
Kind Regards.
LavUser
(4,220 Views)
Before i try to understand what you did in LV. I made a different VI from the description you gave.
Maybe this is what you want.
BTW: I am not helping out concurrent firm here  Smiley Sad  Smiley Wink am i ?  Modbus and alarms, is it for a safety system ?
Message Edited by K C on 06-14-2006 09:30 AM
(4,218 Views)
do you mean something like this:
Because in an Array every control or indicator has the same name. You just can have one name. In an Cluster you´re free, There you can have independent names. And with Property Nodes you can set the Captions. Not the Lable!!!!!:
Hope this is what you´re looking for!
Alex Rudolph
NI Switzerland
(4,210 Views)
Thank you and almost what I need. I see that you can get the activ bit much better with your programm. But the thing must running so:
On modbus protocol I have 120 Boolean, those are alarms, it means, when they are equal to 1, it means that exist an alam. Where when come an alarm I will see - for instance -:
Bit 1 = 0 means "nothing - empty "
Bit 2 = 1 means "Daniel"
and so on. Mein programm can do that, but now I need to put "Daniel" when bit 2 is equal to 1. On the array is not possible, because the array accept only one text to all. And like a cluster, could be possible, but I do not know how!!! . Maybe will be easy but I do not have a lot experience.
And it is for an alarm system for a ship but only for a simulator. So don't worry!!! Smiley Very Happy
Kind Regards,
LavUser
(4,204 Views)
