GPIB and MAX issues
I am pretty new to this GPIB business so I hope this isn't too stupid of a question.
MAX 2.0 is not recognizing our PCI-GPIB card (it is made by computerboards not NI). When I search for it under device (in MAX) I just see the com and lpt1 ports. When I look under the system folder/device manager, I see the card under CBI_GPIB perfectly fine. The weird thing is that if I use a simple GPIB vi in labview it can communicate with my device fine. If I try using the VISA interactive controller I am not able to see the card either. I updated the drivers in MAX but I don't think that should have a lot to do with it.
please help.
thanks,
ciro
(4,213 Views)
It is not a stupid question. At first it is a little confusing to see the relation between the components.
MAX will only shows NI boards. Each hardware on your system has a device driver, which allows the communication with the device. For the NI PCI-GPIB board the driver is NI-488.2. MAX knows how to communicate with the driver to configure the board. MAX is basically a configuration and test utility. Also, the driver is in charge of providing the language interface files, so you can use the device with certain programming enviroments. So the NI-488.2 offers header and c files for C, .bas file for Visual Basic and VI for LabVIEW. These components only access the NI-488.2, so they only work for NI GPIB interfaces.
The computerboard GPIB interf
ace needs to have its own driver, its configuration utility and provide the appropriate interface files (VIs, h and c files, etc). Check the board's user manual for details.
DiegoF
National Instruments.
(4,213 Views)
Just a quick follow-up question. The reason I am researching this is that I found some drivers for an HP device (HP4284A) on the NI website. I tried using the vi's but they haven't worked. I found that the vi's were not recognizing the gpib device. I know that the vi's are using the VISA protocol. Since I am not using an NI board does that mean that VISA will not recognise the device either?? I tried using that control interface for VISA and it doesn't know it is there.
thanks again,
ciro
(4,213 Views)
It depends if the driver of the board is VISA can interface with VISA. You should contact ComputerBoards for information on how to comunicate with VISA.
Here are a couple of KB articles that deal with comunicating with HP boards. As you can see, the HP driver provides some configuration utilities to use the boards with NI-VISA.
DiegoF.
(4,213 Views)
forgot to copy the links:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/3b3626d9c1f999218625694200791ad7?OpenDocument
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/e56d3d4866be0a8a86256942006626f0?OpenDocument
Diego
(4,213 Views)
