GPIB and ancient HP signal generator
Hi all,
  I'm trying to automate a really old HP 8672A signal generator
(3,832 Views)
RFMike06,
If your device has GPIB, serial or some other bus you can hook up to a modern computer you should be able to talk to it. The hard part is, do you still have access to the manual that will have the list of commands that the device recognizes. The problem with older instruments is that the standardized command set of 488.2 had not been created yet so every old device is a bit different.
Here is a great jumping off point if you are new to instrument control or a veteran: Developer Zone: Instrument Control Fundamentals
-Marshall R
(3,780 Views)
(3,754 Views)
