GPIB buffer size limitations?
Hi
I'm using the example in Calling NI-488.2 Functions Directly in Excel to read data from an instruments internal memory (Keithley 6517B) directly to an Excel sheet. But no matter how much memory I preallocate for the data I can't get more than 2160 bytes of data. I've tried both Excel 2003 and 2010 with the same results.
Snippet:
sBuffer = Space$(65536) ' string buffer may have to be larger
Call ibrd(udDevice, sBuffer) 'read response and store in sBuffer
Also, the NI-488.2 Communicator tool in MAX seems to have a similar limitation in that it doesn't read more than 2000 bytes (ibcntl: 2000).
When I use the exact same command string (":trace:data?") in LabView all 3240 bytes available in the instruments memory is received without any problems.
I wanted to use Excel since it's such a simple application and my LabView license doesn't include the LabView builder.
Any suggestions on how to solve this?
Jocke
(6,807 Views)
It sounds like your read is terminating when a termination character is detected. The data is hex isn't it?
Why not use VISA functions? GPIB is so last century.
(6,796 Views)
The data is ASCII.
If I'm getting a termination character, shouldn't my VBA-program and the NI Communicator stop at the same character? Now they don't.
I'll try using VISA instead, using this example
Do you have any other relevant resources?
Thanks!
(6,765 Views)
Hi Joker
I agree with Dennis_Knutson I would have a go with VISA and have a look at the drivers created for it. They will be for LabVIEW but may be of help to you
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E921E659CE034080020E74861#seeBelow
(6,755 Views)
Since you say that LabVIEW code returns the correct data, use I/O Trace to capture the commands of both programs. Compare the differences.
(6,751 Views)
