GPIB card or GPIB to USB
I am not an experienced LabVIEW developer. Currently I have a job of acquiring waveform form Tektronix TDS380 Oscilloscope (GPIB interface) with LabVIEW. I found a IVI Driver from nhttp://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E960D659CE034080020E74861.
I noticed that the driver type is IVI. Does it mean I could only install a GPIB card on PC instead of using a GPIB to USB cable to finish the job.
Thanks!
(2,874 Views)
Accepted by topic author mIAO945
If you mean a USB to GPIB converter then just install the GPIB drivers and probably VISA (which LabVIEW should of installed)
(2,833 Views)
