Modbus IO server error -1967353900
I am using the NI 9871 module in a cRIO-9066 chassi to do Modbus communication.
I have deployed Modbus I/O Server 16, NI-VISA 16, NI-VISA Server 16, NI-Serial 9871 Scan Engine Support 15 to the Realtime system (and of course a lot of other packages)
When I try to use read a variable from the Modbus I/O Server (regardless whether on the host or on the target) I get the error -1967353900 (The Modbus I/O server failed to allocate a serial port) The vi I use does nothing except reading a Modbus I/O variable.
I can open the serial port I am using with the VISA Test Panel, and manually send a Modbus command to the device I am trying to communicate with, and receive a correct Modbus answer.
I have read "Troubleshooting Modbus I/O Servers" but it does not help me.
Does anyone have an idea what the problem is?
(I have an ongoing service request on this issue, but I thought it would be useful to ask the communutiy at the same time)
(4,423 Views)
Hey,
I see you have an SR open, can you say what steps you tried so far? So that we are not walking in a circle : )
Kind Regards,
-Natalia
(4,394 Views)
Hello, thank you for your interest!
The steps I tried so far in conclusion:
Removing and redeploying the cRIO software on the target
Removing everything from my code except a single shared variable call to a Modbus IO server variable.
I have tested calling the variable both on the host and the target.
Opening the VISA Test Panel manually and confirmed that I can communicate with my Modbus device via the same com-port that the Modbus IO server is set to use. (I do not have the VISA Test Panel open while I try accessing the Modbus IO server variable...)
As for now, my SR representative did not have any further ideas, but she was going to talk to some colleagues.
(4,389 Views)
Hi perhult,
I'm about to undergo the same feat - 9066 reading out data from a device using modbus and found this:
http://digital.ni.com/public.nsf/allkb/F4EC738858058A9786257E460054618F
Think this can be relevant for you?
Cheers
(3,689 Views)
