08-05-2005 03:33 PM
08-08-2005 03:30 PM
08-08-2005 04:06 PM
I have successful communication to activate the laser and to adjust the power and wavelengths.
I have found that even though I can modify the power level to what I specify, when I query the laser for its output power it always returns the same thing 4.1 mW instead of the 10 or 15 mW that the display reads out. The wavelength can be controlled by commands and also returns the correct numbers when queried.
The polarization analyzer is responsive when the internal laser is being used but not when the internal is turned off and the external is activated. I have made sure the internal shutter is off. The signal appears on the poincare sphere but the data values being displayed are not retrievable.
I will keep trying and call in for help soon if I do not figure it out.
thanks.
