05-26-2009 10:16 AM
Hi, I'm using Labview and GPIB to control a very outdated Temperature Control device. I can remotely control it's operation just fine, my problem comes when i try to read the sensor data. The Manual for the TC device indicates that the command for reading the temperature off of the device is "WSA" which i input as a command in my vi. Generally, this gives me the temperature readout the first time around, but gives the error -1073807339 when the program loops or when i run the program again. This isn't a large amount of data, simply 7 bytes. The error indicates a timeout error, but I already have all of the information that I need! How do I set up my vi/hardware configuration in order to eliminate this error and constantly update my temperature readout on the display from my vi?
Any and all help is appreciated,
Benjamin
05-26-2009 04:03 PM
05-27-2009 01:26 PM
05-27-2009 02:53 PM
05-28-2009 11:35 AM
When I use the "Measurement and Automation" program to input the command directly to the device, if I use other commands, the instrument responds in the proper manner. When I use these other commands in labview, i also get it to behave in the proper manner.
The Query subvi has a write command followed by a read command, which for other instruments has worked fine up to this point. but if you can see a problem with it, please let me know. i would be happy to improve my code. so there is a read command in there, it's just under a subvi.
Back to the WSA command. when i put it into the "Measurement and Automation" program, just the command, I get my sensor data and then 30-50 blank characters followed by a timeout. So I know that the device recieved the command to send the data, and that it responds to the command correctly. it sends the data and then a series of blank characters, as described in it's manual. i also know that the GPIB recieves that data, otherwise it would not show up in the "Measurement and Automation" program. It's just the fact that it times out, like the GPIB doesn't know to stop collecting the data.
What's this MAX program? can u link me to it?
05-28-2009 11:54 AM
First, MAX is Measurement and Automation Explorer.
It sounds like the instrument is not compliant with IEEE-488.2. With a compliant instrument, the EOI line is asserted at the end of a data transmission and an instrument would not be sending blank characters. That means that you do not need to know how many bytes the instrument has available. You just have to request some large number and the VISA Read will automatically terminate. In MAX, you can change the default behavior so that a read will terminate on an EOI or another character. With the GPIB functions, you also have this option with the Mode input.
06-02-2009 08:39 AM
When I use MAX to try to interact with the instrument I get the following picture. This is the same result when I have the any of the configurations in the "Configure EOS" menu selected. If I use the termination byte from the TC's manual, I don't get any response from the machine and i just get blank spaces and then a timeout.
I apologize, i should have put this picture in my first post.
06-02-2009 09:03 AM
06-02-2009 12:27 PM
here is a link to the manual. the termination character and other commands are in section 4.0 and following.
http://www.lakeshore.com/pdf_files/Obsolete/DRC-91C_Manual.pdf
