12-24-2022 09:14 AM
I need to set 5V to E364X series Dual Output Agilent power supply in high limit range and that to in channel 2 in labview. Can you please share example VI to select channel 2 in dual channel instrument with high or low limit range?
John
12-24-2022 10:35 AM
With the examples shipped with the driver you can see how you can set the power supply.
I use this power supply and found that all driver VI's I used are very easy to use.
Try it and show us what you made of it.
Kees
