GPIB interface for E364X series Dual Output Agilent power supply
I need to set 5V to E364X series Dual Output Agilent power supply in high limit range and that to in channel 2 in labview. Can you please share example VI  to select channel 2 in dual channel instrument  with high or low limit range?
John
(1,312 Views)
With the examples shipped with the driver you can see how you can set the power supply.
I use this power supply and found that all driver VI's I used are very easy to use.
Try it and show us what you made of it.
Kees
(1,289 Views)
