08-07-2012 06:59 PM - edited 08-07-2012 07:01 PM
I have a Keithley 2600 connected with an NI GPIB ENET100.NI488.2_V302 and LabTracer 2.0 are installed. While I run Labtracer error message always popout stating the following:
LabTracer 2.0 has tested for a functioning GPIB interface card enumerated as GPIB0 and received an error. This means that although VISA is correctly installed no card in the system is set to be GIBE. Either the GPIB interface to be used for testing is not correctly installed or it was intentionally installed as some other interface number. View LabTracer2_Release_Notes.htm in the data\LT directory installation archive or help window for complete information on the instrallation process. You can use Labtracer, but you will not be able to communicate with instruments unless you change the GPIB settings or install a GPIB card. If your GPIB card is simply set to some other enumeration (like GPIB1, GPIB2, etc.) then change the GPIBborad # entry at the top of the instrument setup window to the correct value.
However the settings shown from Measurement & Automation Explorer of the device says "GIBE". So I don't know what else should I change to make it work.
Anyone seen this before?
Thanks.
Xinfeng
08-08-2012 12:40 PM
