GPIB on the Mac
I'm trying to troubleshoot a GPIB (ENET and PCMCIA) problem on the Mac. Any
comments or suggestions??
- GPIB timeouts don't work. If I (for example) request data from a device
that doesn't have any, I would expect a timeout so that I can handle this
error. Instead, my entire system hangs and has to be rebooted! I've tried
this under several versions of MacOS (7.6.1, 8.1, 8.6), different machines
(Beige G3, PB3400, UMAX S900) and NI GPIB hardware (ENET and PCMCIA), with
the same results.
It seems to me that the NI-488.2 drivers (I've tried different versions...)
are not playing nice with the MacOS.
ANY MAC ENTHUSIASTS OUT THERE THAT CAN HELP? I really want to stick with
the Mac for my test systems, but NI seems to have pushed the Ma
c support
to the back burner..
(3,851 Views)
Hello David,
I ran into the same problem while trying to update some (really) old VIs
from a Windows 3.1 / 486 system to LabView 5.1 on my PowerBook G3 (Bronze
- no FireWire) using the network connection and an ENET GPIB box. They ported
over well enough, but I had to replace some of the old GPIB Read / Write
VIs and re-wire them. That seemed to work o.k., but then I thought I should
swap out the old instrument drivers with the latest ones I downloaded from
the web (HP662XA Programmable Power Supply). That's when the VIs started
to freeze my machine.
After looking inside the instrument drivers, I noticed that they use the
VISA VIs instead of the GPIB read, write, etc. VIs.
There's some difference in the wiring, but, I would suggest trying to replace
the VISA VI
s with the GPIB VIs. I'm sure you'll have to do some wire-work,
but I'm optimistic that'll do the trick.
FYI: The setup is used to control a HP6626A programmable power supply to
reverse-bias a solar cell under a solar simulator to create the points for
a current-vs-voltage curve for the cell.
Good luck,
--- Dan Sakoda ---
Naval Postgraduate School
Monterey, California
Any>comments or suggestions??>>- GPIB timeouts don't work. If I (for example)
request data from a device>that doesn't have any, I would expect a timeout
so that I can handle this>error. Instead, my entire system hangs and has
to be rebooted! I've tried>this under several versions of MacOS (7.6.1,
8.1, 8.6), different machines>(Beige G3, PB3400, UMAX S900) and NI GPIB hardware
(ENET and PCMCIA), with>the same results.>>It seems to me that the NI-488.2
ns...)>are not playing nice with the
MacOS.>>ANY MAC ENTHUSIASTS OUT THERE THAT CAN HELP? I really want to stick
with>the Mac for my test systems, but NI seems to have pushed the Mac support>to
the back burner..
(3,851 Views)
